- Clutch suggestions
- dumb question..?? Where's my voltage regulator - 1994 F250 IDI with factory turbo
- ats install still questions please assist
- Abs diagnosis
- Has anyone dealt with this company - Hawkins Transmissions?
- Occasional hard starting
- WHAT TURBO TO USE
- blowing coolant out of res cap emergency
- 216k and the injection pump is done for
- 83 rear tank CLKC
- no brakes, vacuum pump issue, stranded in Prudhoe Bay Alaska. Help?
- This is why I love these IDI's!
- 3:55 & E4OD bad combo?
- 1994 idi loosing coolant
- BARELY PASSED E TEST TODAY
- Need some electrical help
- 7.3 Hard start when warm.
- trans hard shift
- Overdrive off or on?
- my electric fan conversion
- Someone help!
- 45k 7.3 IDI
- Check this out
- cdr
- 93 F250 7.3L IDI non turbo swap
- Fix or Replace Radiator?
- Failed return line cap Updated 6/30/2013 page 2
- double post ignore this one
- 1988 F250 7.3 has a leak. may be a freeze plug
- Low engine temp
