Clutch suggestions
Old Jun 28, 2013 | 04:27 PM
kla94's Avatar
kla94
Clutch suggestions
It's clutch time for me. Want to go solid mass. Been looking at the LUK LFW140 flywheel and the 07131 clutch kit. Can get the whole setup for 280$ before shipping. What do you guys think? Just looking for advice and suggestions. Not planning on pulling really heavy loads or street racing, but am planning on doing some to my motor. It says to replace the master and the slave cylinder. What's up about that?
Old Jun 28, 2013 | 07:39 PM
airdale94's Avatar
airdale94
I just put a Luk kit in from NAPA. 12" upgrade. Already have SMF. And although it's 100 times better than my oil soaked wore out on 1 side old one, I was not impressed with out of box appearance. Made in China. Performance is fine. Haven't towed anything, but it just feels like a "car" clutch. I would look into South Bend, or others. Nows a good time to do the rear main also. Your year may have the upgraded double lip teflon seal allready, so you may not need one. Diddn't replace the slave cyl. though, so maybe that would improve performance.
Old Jun 28, 2013 | 09:09 PM
tecgod13's Avatar
tecgod13
I did a Luk kit last year, and that price sounds about right, mine was from ebay.
Pedal felt a lot better, and its been working fine, towing included.
It probably says to replace the master and slave so you buy more of their parts. If they are working fine, I wouldn't bother. Might be a good time to flush some clean fluid through. (just becareful not to run it empty, these are a pain to bleed!)
Old Jun 28, 2013 | 10:27 PM
Red454sedgwick's Avatar
Red454sedgwick
My napa one has held up to all my towing, but the throw out bearing only lasted a year.
Old Jun 28, 2013 | 10:57 PM
kla94's Avatar
kla94
Thanks guys. Found the LUK on RockAuto.
It probably says to replace the master and slave so you buy more of their parts. If they are working fine, I wouldn't bother. Might be a good time to flush some clean fluid through. (just becareful not to run it empty, these are a pain to bleed!)[/QUOTE]
Replaced the master already. I found a trick to bleeding it. Just open the bleeder and kick the slave cylinder down at an angle then wait a few. Worked great for me. My pedals way down and getting noises from it now. Afraid my flywheel might be fixing to come apart.
Old Jun 29, 2013 | 12:51 AM
hairyboxnoogle's Avatar
hairyboxnoogle
Im going with Valair
Old Jun 29, 2013 | 10:57 AM
Ford F834's Avatar
Ford F834
What lead you to arrive at that choice? Just curious. I'm as clueless as the next guy except I know some are considerably more expensive than others, presumably commensurate with quality...
Old Jun 29, 2013 | 11:27 AM
kla94's Avatar
kla94
Guess it all depends on what you want. I'm only planning on a moderate build for now. 250 hp or so. Biggest things I pull are firewood and around 6,000 lb 5 th wheel camper. Not going to be racing either. That Valaint is impressive, but overkill for me.
Samantha99
1997 - 2003 F150
Feb 19, 2019 03:54 PM
Steve Harlow
May 15, 2018 07:58 PM
Greg5OH
Jun 18, 2012 10:47 PM
staysbroken
1983 - 2012 Ranger & B-Series
Apr 26, 2012 11:38 AM
northernowl
1997 - 2003 F150
Jan 16, 2006 11:22 PM
