cdr
Old Jun 24, 2013 | 06:44 PM
dumptruck denny's Avatar
dumptruck denny
cdr
i have a 1988 450 superduty 7.3 using a lot of oil since oil change blue smock out the exhaust. i read something about the cdr, what is it and where is it located thanks new to site
Old Jun 24, 2013 | 06:47 PM
powerstroke72's Avatar
powerstroke72
Welcome to FTE Denny.
I've moved your thread to the correct forum for your issue, truck, and engine. Someone will be along shortly to help you out.
Old Jun 24, 2013 | 07:03 PM
dumptruck denny
thanks; like i said iam new
Old Jun 24, 2013 | 07:04 PM
powerstroke72
No problem......you're doing just fine. This particular forum will be the best one for seeking help with your issue.
Old Jun 24, 2013 | 07:06 PM
dumptruck denny
ok thanks again
Old Jun 24, 2013 | 07:43 PM
whalebus2112's Avatar
whalebus2112
The cdr is the tuna can looking thing right behind the air cleaner. Some say you can clean them with gas or some kind of cleaner an others say replace.
I got my off a Donor truck when I added the turbo and it makes mine burn oil. I tried cleaning and no luck. I am about to order one
Old Jun 24, 2013 | 07:59 PM
Chevy_Eater's Avatar
Chevy_Eater
---->Click What is a CDR?
Old Jun 24, 2013 | 08:23 PM
dumptruck denny
thanks niles
Old Jun 24, 2013 | 08:25 PM
dumptruck denny
mine is a non turbo would it still have it.
Old Jun 24, 2013 | 08:28 PM
Forddiesel17's Avatar
Forddiesel17
yes on a non turbo it is on the back of the intake manifold where the air filter mounts.
Old Jun 29, 2013 | 12:49 PM
dumptruck denny
cdr.on 88 7.3
do i have to go to a dealer to get the cdr unit for the 1988 7.3
Old Jun 29, 2013 | 01:11 PM
Phy's Avatar
Phy
Here's a thread with the part number, and a link to a site that has 'em...
https://www.ford-trucks.com/forums/1...tion-help.html
Old Jun 30, 2013 | 05:15 PM
dumptruck denny
just got back on the comp. after i posted that.so thanks a lot that was a really big help
Old Jun 30, 2013 | 05:31 PM
dumptruck denny
just incase the cdr is not the problem and i decide to change motors ,i can get the 1994 7.3with turbo out of a crew cab with a automatic. will flywheel and every thing fit in my 1988 f450 superduty 7.3 non turbo dump with the 5 speed standerd shift tranny.how about the computer are they the same[ please help].
Old Jun 30, 2013 | 05:55 PM
Chevy_Eater
As long as it's an IDI and not a powerstroke. Both were sold in '94.
