- Did anyone know whats up with Festus Hagen
- 4speed to 5speed OD
- New owner 1992 f250 xl 7.3 IDI question
- Does this USED turbo kit look complete?
- Smoke Smoke Smoke dumping fuel :-(
- thermostat question
- Next job. Coolant change. The right coolant? I want to avoid using straps and adding additive mysel
- New Injectors Still Smoking
- 92 F350 7.3 o/d light flashing and shifting issues
- All this vacuum pump talk....Now mine went out!!
- Name of the pulley that attaches to the vacuum pump on a 94 E350 7.3
- Possible TPS adjustment problem
- Fuel Leak Help
- '89 F250 Differential Fluid Change. HELP!!!!
- Excessive coolant pressure.
- Bronco tank sending unit
- Yellow lights started coming on by themselves. Wiggled this piece and it has a direct effect.
- Alternator putting out 13/13.5v. Do I need to replace?
- Go figure.....
- 7.3 idi non turbo to 7.3 idi turbo
- Friggen mechanics man... Put the relay ground wire to the glow plug post
- Exhaust routing
- Should I Fummins?
- Injector pump from non turbo to turbo... Work??
- charging problem
- shift points C6 on 6.9L
- Truck has been running 20psi under the tires recommended psi level
- Brake problem. Possibly vacuum related?
- Terrible noise and won't go
- Heat shield, more Sidewinder issues...
