Does anyone know if there is a carby single plane or tunnel ram manifold made to suit efi heads. If not could someone post pics of the efi lower(are they two piece) manifold especially the top. Maybe I can cut it and/or add a plate to accept a couple of L.P.Gas carbs.
Thanks
Check on EBay for pictures, the EFI intakes are listed every now and then.
The EFI intake is essentially a dual plane 4bbl intake with each pair of carb primary and secondary holes joined in one elongated opening. On top of this goes a gooseneck piece with two (side by side) passages. This connects to the twin throttles. The gooseneck mounts the throttles essentially above the center of the lower manifold with the thorttle airflow flowing horizontally towards the firewall.
You're not going to be able to convert this to a single plane manifold unless you ground off all the passages and weld on a new top and dividers.
