Another question??? RPM'S???
Old Nov 16, 2001 | 07:55 PM
aintskeered's Avatar
aintskeered
What is the maximum sustained RPM's on a C6 3 speed, with EFI 460?
Old Nov 17, 2001 | 01:10 AM
mrlaserboy's Avatar
mrlaserboy
[updated:LAST EDITED ON 17-Nov-01 AT 02:19 AM (EST)]Dunno about maximum sustained but my cruise rpms at 75 is about 3400 rpms. I did a trip from MN to NH and back a couple months ago, did 3200-3400 rpms for hours on end with no ill effects.
Old Nov 17, 2001 | 02:19 AM
cobrajet's Avatar
cobrajet
also depends on what kind of gear ratio you are running! what kind of sustained running are you refering to? running down the highway at the speed limit, or at wide open throttle running down the highway? a C-6 should be able to handle in the 4,000 r.p.m. range all day long if it has some mods to it, or even a stock trans that may not have to many miles on it. the trick is to keep the transmission running as cool as possible ( i.e. Transmission Cooler ) this is the number 1 enemy of any trans ( heat )! CJ........
Old Nov 17, 2001 | 02:22 AM
cobrajet's Avatar
cobrajet
skidmarks82
1997 - 2003 F150
Oct 5, 2015 08:45 AM
JoeDaf
21
Aug 19, 2015 11:33 AM
lake
Mar 11, 2015 01:47 PM
gekitch111
1978 - 1996 Big Bronco
Mar 12, 2007 04:34 PM
FTE Ken
Sep 12, 2001 08:31 PM
