460 needs new carb
Old Sep 18, 2005 | 02:42 PM
BigBody's Avatar
BigBody
460 needs new carb
I have a 77' f-150 that a 460 has been swappd into. It has a carter AFB 4 barrel on it now. It needs replaced.
I want a good performance carb. Seems like most people tend to say 750 holley or Edelbrock. I just want some good power. Mileage doesn't matter as long as I'm getting atleast 5 or 6
Whats some good choices?
Kyle
Old Sep 18, 2005 | 08:56 PM
kevinupchurch's Avatar
kevinupchurch
Is there any modifications done to the engine or is it stock.
Old Sep 18, 2005 | 09:40 PM
BigBody's Avatar
BigBody
I just bought the truck. Appears to be pretty stock.
Old Sep 18, 2005 | 10:01 PM
T18skyguy's Avatar
T18skyguy
A 750 Edelbrock will do just fine. Start with both idle mixture screws at 2 turns out. Hook a manifold pressure gauge to the bottom right port on the carb. Now with the engine warmed up and no choke activated, turn both screws in 1/4 turn at a time until you get the highest manifold pressure(should be 18-20) Adjust the idle speed if it gets more than 30 rpm too high for what it should be. Each time you make an adjustment give the engine a minute or so to react. Once you get the highest manifold pressure dont go any further. Usually this means you go a 1/4 turn to far and dont see any improvement on the gauge and you go back a 1/4. This has always worked for me.
Old Sep 18, 2005 | 10:50 PM
BigBody's Avatar
BigBody
Will this carb be a step up from the carter? Should I feel a power gain? Should I got with electric choke?
Old Sep 18, 2005 | 11:20 PM
monsterbaby's Avatar
monsterbaby
and edelbrock 750 is the same thing as a carter. exactly the same thing infact you can even use the same rebuild kits.
if your going to run this engine above 5000 rpm a lot then you need the 750, but if your not going to see it above 5000 rpm much a 600 or 650 is actually plenty of carb on a 460 cid engine that is stock or basically so.
Old Sep 19, 2005 | 12:07 AM
Bear 45/70's Avatar
Bear 45/70
If it has a stock cam it won't have any extra power up at 5000 rpm. So the big carb will be a waste of money.
Old Sep 19, 2005 | 06:58 AM
BigBody's Avatar
BigBody
So, should I look into rebuilding my current carb?
Old Sep 19, 2005 | 10:46 AM
Bear 45/70's Avatar
Bear 45/70
The instructions that come with the kits are pretty good, if you have some basic mechanical skills. Mainly you want to pay close attention to how the carb comes apart and get it back together right (some guys use a camera to take pics, a digital camera is real good for this stuff). Double check the float setting.
Old Sep 20, 2005 | 07:21 AM
BigBody's Avatar
BigBody
The real problem is... When you floor it, it will stutter. You guys think if I rebuild the carb it will help it?
Old Sep 20, 2005 | 01:29 PM
Bear 45/70's Avatar
Bear 45/70
Can't hurt and may well fix the problem.
Old Sep 20, 2005 | 06:31 PM
BigBody's Avatar
BigBody
So, for the rebuild kit.... Should I go for the edelbrock 750? That one comes with new floats. The carter kit does not.
Old Sep 20, 2005 | 07:42 PM
Bear 45/70's Avatar
Bear 45/70
I always replace floats if there is a flooding or over rich problem, otherwise no.
xirxious
Dec 18, 2012 08:32 AM
Jimmyrig
Nov 20, 2012 09:31 PM
az4x4bronc
Feb 14, 2010 08:07 PM
kilbrethj
Oct 5, 2007 02:01 AM
Vin Man
26
Jul 5, 2003 04:25 PM
