Need timing advise 460
Old Sep 15, 2005 | 02:38 PM
olfordsnstone's Avatar
olfordsnstone
I have a 68 460 in my 74 F250 4x4. It has just undergone a rebuild with a moderate cam, dished pistons to allow 9.2:1 compression and 87 octane fuel, 68 closed chambered heads... I set the timing acording to the specs at 10 degrees BTC. It seems to run good at 10 degrees but when turning off the ignition, it will diesel for a few before shutting down. It seemed like the timing was too far advanced. I backed off the timing a hair, until it quit doing that and all was well for a little while until like an hour later when it started doing it again at the more retarded timing. I parked it after that but need to use this truck to help a friend move this weekend. Does anyone have any ideas why this would happen???
Thanks in "advance" he he he, Tim
