Low compression in #8 cylinder
Cylinders #1 through #7 have 193 psi to 200 psi. #8 had 75 psi. Spark Plugs with 37,000 (approx miles) on #1 through #7 looked great while #8 was oil fouled to the max.
I loaded the #8 cylinder with air and there was none coming out the intake or the exhaust. I pulled the PCV valve and heard the air coming out through the grommet, along with some fumes. So I have either rings or a cracked piston.
I installed 8 new plugs and all plug wires. I ran some Ris-Lone Ring Sealer and Marvel Mystery Oil in the crank case for about an hour and then let it cool down. I checked the compression again on #8 and the compression went up to 110 psi. The #8 spark plug was again oil fouled. I changed the spark plug in #8 hole and added 1 quart of oil once again and drove the motorhome about 30 miles. I re-checked the compression on #8 cylinder for a third time and it went up to 135 psi. However the coach now smokes like a BEAR after it is warmed up.
Ok, it seems to be rings on #8. I am wondering if the rings will finally free up, given enough time and still using more detergents.
Also, could this possibly effect the injector? I am wondering if the injector is coked up so that the cylinder is not firing at full strength to help free up the rings.
Help ... if someone knows of a better way to free up the rings with out tearing down the engine, feel free to step in. The location of this engine will mean that I have to drop it out the bottom of the motorhome even to pull the heads. UGGGGGH!
I am thinking that the valve guide seals might also be in bad shape. I can get the valve covers off, with a little work. Any suggestions?
"Doc"
