Adjusting valves
Old May 14, 2006 | 10:44 PM
RangerTuff05's Avatar
RangerTuff05
Adjusting valves
How do you adjust the valves on a 1977 460 V8.
Old May 14, 2006 | 10:53 PM
Mil1ion's Avatar
Mil1ion
You need the general automotive or 385 engine series forum.
It's done the same way as any other year 289/302,351M/400, 429,460 with hydraulc valves.
The 77 truck has nothing to do with the topic.
Old May 15, 2006 | 02:57 AM
Torque1st's Avatar
Torque1st
Posting Legend
The valves are not really "adjustable". If the valvetrain is worn beyond limits replacement parts are required and the valves "adjusted" if needed by shims under the pedestals. When valvetrain parts have worn thru the surface hardening rapid wear rates are experienced, therefore the parts must be replaced.
Old May 16, 2006 | 10:07 AM
RangerTuff05
What parts do i need to be looking into to replace
Old May 16, 2006 | 09:57 PM
RangerTuff05
Does no one respond to threads anymore?
Old May 16, 2006 | 10:55 PM
j.m. ray's Avatar
j.m. ray
i am not sure what problems you are having.they are not adjustabe..can be converted with machine work.common wear items are cam, lifters,pushrods, rocker arms, and most often ,valves and seats
Old May 17, 2006 | 01:08 AM
monsterbaby's Avatar
monsterbaby
Only other issue is if you rebuilt the engine, and you had the heads and block milled then you need to add a corrosponding amount of shims under the pedestals to make up the difference or a corrospondingly shorter pushrod. As others stated basically that engine in stock from doesn't have adjustable valve train.
