Adjjusting valves
Old May 15, 2006 | 01:30 PM
RangerTuff05's Avatar
RangerTuff05
Adjjusting valves
How do you adjust the vavles on a 1977 460 V8 engine. They are rattling a little bit
Old May 15, 2006 | 02:36 PM
Bear 45/70's Avatar
Bear 45/70
There is no adjustment. If they are rattling that means there is wear beyond the limits of the hydraulic lifter to compensate and at a minimum you need longer push rods. But it is more likely, the noise isn't valve train noise and if it is you need to be doing a valve job and possible a cam and lifters.
Old May 15, 2006 | 02:53 PM
460me's Avatar
460me
You can set your lifter-preload with a shim kit.That's a start.Sounds like you might have more troubles,maybe.
Old May 15, 2006 | 03:35 PM
RangerTuff05
what do i need to look for and what do i need to do. I guess what i need to know is what i need to put into it and what you think it will cost me
