460 Heads
Old May 5, 2006 | 02:41 PM
ticktoc4's Avatar
ticktoc4
460 Heads
I would like to know why non fuel injection heads are not able to be used on FI motor when continuing to us FI?
Old May 6, 2006 | 09:22 AM
alans77crew's Avatar
alans77crew
not for sure on this but they have different size ports and the valve angles are different not to mention the bolt pattern is also different Like I said not for sure so if there s any one who is speak up!
Old May 6, 2006 | 11:09 AM
monsterbaby's Avatar
monsterbaby
alans77crew that is basicallly it, due to the difference in the intake bolt patterns the intakes physically won't bolt up. but the valve angles are not revised just the intakes are different ports and bolt patterns.
Old May 7, 2006 | 12:21 PM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
I just tried matching up the gasket for my 86 engine to the 93 EFI heads. The bolt pattern appears to be the same, but the intake ports are higher up in the casting. This was just a quick check (the heads are still bagged up). It looks like you could switch intakes, but you would have one H*** of a leak. I do know that Ford changed the PNs on the valve train components too.
Jimmie MORGAN
Mar 22, 2008 09:48 AM
Junkfood
21
Apr 12, 2004 02:54 PM
hotrodmerc
Oct 26, 2003 09:56 AM
robrowe35
1997 - 2003 F150
Sep 8, 2002 07:49 PM
Nate_64
May 30, 2000 09:52 AM
