390c
Old Nov 4, 2002 | 11:26 AM
johnwhipple's Avatar
johnwhipple
390c
I went to change valve cover gaskets and exhaust manifold gaskets and found out the gaskets I got from autzo*** are the wrong size. Is the bolt pattern and port size completely different from other 390's? Help!
Old Nov 4, 2002 | 12:13 PM
ZRX61's Avatar
ZRX61
390c
I went to a parts place for a set of 390 exhaust gaskets last week & found out there are 3 different kinds. Had to go home & get an old one to match em up..
Old Nov 4, 2002 | 02:46 PM
Ratsmoker's Avatar
Ratsmoker
390c
Give me the year of the truck engine and I will give you part numbers so you don't have to rely on the geniuses at autozone.
Old Nov 4, 2002 | 04:28 PM
johnwhipple
390c
That's part of the problem. The guy who sold me the truck said it was a 75. I go to the parts store and they don't have anything for a 390c and none of the gaskets are small enough. Finally, i go to a family owned parts store where the iq level is significantly higher and they find gaskets that fit 302's that will work on my ports. WHat the hells going on? I've got a 390 intake, I've got valve covers that say 390c on them, but 390 parts don't fit.
Thanks
Old Nov 4, 2002 | 06:32 PM
jowilker's Avatar
jowilker
390c
John, First of all there isn't a 390c, there is a 351c. Do your spark plug wires look like this on each side \\//? That is a give away for the FE engine family that the 390 is a part of. A set of Felpro gaskets will work.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member 0004 since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
Old Nov 4, 2002 | 11:20 PM
Ratsmoker's Avatar
Ratsmoker
390c
Another way to see if you have an FE is to look at where the intake manifold contacts the head. The valve cover goes over the head and part of the manifold vs. other ford engines where the valve cover only covers the head.
Old Nov 5, 2002 | 02:17 AM
Scotty1's Avatar
Scotty1
390c
Sounds like to me he has a Smal Block and not a big block. The info given by the previous should let you know what engine you have.
Scotty
Old Nov 6, 2002 | 11:49 AM
johnwhipple
390c
O.K.
I've got a number off the intake: 13726543. If this helps anybody identify this I'd really appreciate it.
Thanks
Old Nov 6, 2002 | 04:49 PM
jowilker's Avatar
jowilker
390c
John boy, me thinks you found the engines firing order.
John
jowilker email me
Old Nov 6, 2002 | 04:50 PM
karlsd's Avatar
karlsd
390c
John, the simplest way to ID your motor is to count the number of bolts on each valve cover. If there are 5 bolts on each, you have a FE series big block (probably a 360 or a 390). If there are six bolts, you have a Windsor small block (289, 302 or 351W). If there are 7, you have a 385 series (429, 460) big block. Finally, if there are 8 on each valve cover, you have a Cleveland/Modified (351C, 351M, 400M).
Old Nov 6, 2002 | 08:32 PM
Like M. Fords's Avatar
Like M. Fords
390c
jowilker has a point about the firing order. 13726548 is the standard for 351C/M/W and some 302HO. All automotive FE's use 15426378. Since there is only one "C", my guess is the engine in your truck is a 351C.
Old Nov 8, 2002 | 10:58 AM
johnwhipple
390c
I appreciate everyones help. This has cleared up much confusion on my part as I'm new to the world of automotive mechanics. 351 it is!
Old Nov 8, 2002 | 03:41 PM
karlsd's Avatar
karlsd
390c
So which 351 is it? Do you have a Windsor, Cleveland or Modified?
Old Nov 8, 2002 | 06:48 PM
Like M. Fords
390c
Martin Torres
Oct 22, 2016 07:35 PM
Manbeerbear
Sep 17, 2016 12:14 PM
Björn
Jan 19, 2014 08:53 AM
klatt_89
May 20, 2007 06:25 AM
Rockershaft
Sep 27, 2005 01:42 PM
