360 spark plug gap
Old Nov 6, 2002 | 01:37 PM
proeliator's Avatar
proeliator
360 spark plug gap
Old Nov 7, 2002 | 01:16 PM
dotty's Avatar
dotty
360 spark plug gap
Hi, can any one tell me what the plug gap on a 74 360 should be please?
Regards - Paul
Old Nov 7, 2002 | 02:13 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
360 spark plug gap
points ignition .035
electronic ignition .045
Josh
Old Nov 7, 2002 | 02:53 PM
dotty's Avatar
dotty
360 spark plug gap
Thanks - Paul
Old Nov 7, 2002 | 06:12 PM
Like M. Fords's Avatar
Like M. Fords
360 spark plug gap
While on the subject of plugs, is there a colder plug than Autolite 45? I just don't want to look dumb and ask for Autolite 43 or 44 if there is no such beast.
Old Nov 7, 2002 | 06:45 PM
Bullitt390's Avatar
Bullitt390
360 spark plug gap
There is a 44, but might be hard to find.
I use Champion plugs myself, RF11YC to be exact, but for the longest time I used RF9YC. I cannot find those anymore, but with my newer engine I really do not need them.
Just curious, but why do you need a colder plug?
Josh
Old Nov 7, 2002 | 08:11 PM
Like M. Fords
360 spark plug gap
Just to see if I can reduce some pinging when I tow without retarding the ignition so far or paying for the more expensive gas. I have never had a problem with fouling the 45's; they almost seem to be too clean. And colder plugs don't rob any power, so I figured it was worth a try.
Old Nov 8, 2002 | 07:09 PM
Bullitt390's Avatar
Bullitt390
360 spark plug gap
Although changing spark plugs can reduce pinging they aren;t the only source of the problem.
Flashing in the combustion chamber, valve reliefs on the piston, exhaust valve edge, carbon deposits etc. all contribute to pinging.
The "rattling" of the valves is TWO flame fronts colliding and causing the valves to flutter.
Reading plugs is really a science. Some like to have the "ring" halfway up the insulator, others want it at the base. Some like to see graying on the electrode. Some side gap, and so on.
If your plugs are clean, leave 'em.
Josh
Just something to think about.
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
Mar 9, 2016 12:40 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
Roachfood
Mar 11, 2002 10:21 PM
