- Air Pump
- Key switch start position is dead
- heater control valve
- Adjusting caster? Manuals says no, mechanic says yes...
- Need some advise, everyone read please.
- 390 distributor bushings
- Inline 6 to a 351W
- 79 Ford F250
- Bed & Hood for a 78 F-150
- looking for a bed
- disc brake matchup
- spring slap
- Alternator upgrade
- fuel tank sending unit.
- Carb Suggestion
- axle id
- --Are all frame "width's" the same for these years
- Problem with lights blinking off and on...
- Tranny ?
- Swapping in a 460
- Oil Weights and a Few Questions
- good ol' ford
- aod on a '78 302
- Timing a 429/460
- Gas Tank
- Q about fuel pump and filter
- U-joint doesn't match rear end...
- 1978 F 150 4x4
- Driveshaft Slip Yoke
- Some sort of heater hose / vacuum switch?
