- bucket seats outa a 87mustang?
- Need a way to clean out heater in 74
- Power Steering fluid?
- Online parts catalogs
- Fouling plugs, what can I do ??
- Radiator Fluid Circulates or Not?
- In the process of changing 74 to 78/9 steering
- C-6 slipping
- Poor power / Valve lash spec for a 477 cid
- Help with oil pan install, please !!
- "Lazy" turn signals
- Heater/Ac vacuum leak?
- Rusty Bed, fixable?
- 79 F-350 Camper special Info request
- 1977 turn signal switch.... need help
- What carb to use as a replacement for 300 I6?
- Advice on fuse block.
- PTO R/R for 1978 F350 ? ? OOPS, wrong place. I'll post in Tranny section
- Quick, Alternator upgrade...
- Duraspark II conversions
- Body Lift Shift Linkage?
- Need a 2wd lift.
- Window seals - where to buy?
- Dana 60-rear wheel lock nut question
- stock alternator ...
- Help...79' F250 seized
- Help with Tailgate
- Rear Hub 74 3/4 ton
- turning brakes
- Radiator???
