- 1979 front grillshell/headlights/headlight buckets wanted
- Is it worth it?
- Random disconnected bits under the hood ???
- relay, switch, and solenoid - same things?
- "F140" on Data plate?
- Did they make a F250 regular Cab / Shortbed?
- Clutch problems
- Steering problems
- Rattle in Driveline somewhere
- Ignition Module Help
- installing a clutch
- Manual to power brakes?
- strange clanging
- lift/tire size/cutting fenders
- 78 f250 wont move HELP PLEASE
- question about rearends
- 1978 F-150 alpine deck install ??
- 79 f150 won't start, solenoid / relay problem?
- Running Lights
- Exhaust Info needed
- Highboy or not
- 1978 F250 Won't Go Into Gear
- back up light help
- Stalling after 10 Minutes?
- Vacuum Lines/Hoses
- driveshaft length
- air cleaner/emissions
- Need Emissions Diagram 77 f250 460
- 74 F-750 repair manuals
- 1979 color code "D"
