- turn signal doesn't work when lights are on
- Highboy 360 headers?
- FE 390 2v or 4v carbs
- Backfire after modifications
- Gear oil on my front tires
- Anybody got pics of the factory radius arm brackets
- 351w no spark
- Backfire thru carb once I hit 190 degrees
- SuperDuty Hydr0 boost on 77F350
- Valve seals still smoking
- Exhaust 1977 f250 with 460 2wd
- Transmission cover part # help
- 79 bed questions
- What is best gasket sealer to use.
- Air Conditioner charging questions
- Lost brakes last night.... Question?
- Do you think my truck is cammed?
- 1977 Highboy axle restoration help?
- I hate my gas sender
- Tires and Rim suggestions
- 74 F250
- A/C blower switch problem
- 4wd hub selector/rotator busted, question for ya.
- Rear Sway Bar End Link for 79 F-350
- Ignition Resistor Wire... Where is It?
- crew cab rear doors locking and latch mechanism
- Camber and Toe-In 1979 F150 4X4
- autolite 4100 carb & fe360
- 16.5" Tires
- Wild horses Gear banger - shift kit. Anyone using it?
