- Radiator advice
- BAD BAD VIBRATIONS!!!!
- Side window wipers
- carbs again
- 4 degrees retard... On 335 AND 385 series???
- Tire size
- F-100 tranny swap
- Break-in?
- 76-F-350
- brake lines
- Fuse I.D. '77 F-150
- Steering shaft on 78 F-250 4WD with P.S.
- Brand new 1979
- my poor truck
- King Pins and I-Beam Bushings for 1974 F-100
- 1978 c6 transmission
- Help: 1970-1980 firing order
- Are firing orders on car and truck engines the same?
- Engine vibrations at idle
- What size is my holley?
- Turn signals not working?
- 79 F150 to a F250 can it be done
- what is a 1976 F-250 crewcab shortbed worth?
- should i buy a 76 f-250?
- Tailgate Trim Clips no Longer Made?.......
- need headers!
- Serious problems...
- 76 dally driver
- took apart the 302 today...have questions
- is the Motorcraft 2150, basiclly a 2b holley
