axle id
Old Nov 4, 2001 | 09:58 PM
bent70's Avatar
bent70
axle id
I just pulled a 60 out of a 77'250 longbed. It's a full floater
and has the numbers on the housing reading: c-37717, 336-76, and 81-2(could be 61-2 hard to tell exactly)
[link:http://photos.yahoo.com/bc/scottsbent70/lst?&.dir=/&.src=ph&.view=t|axle pics] Any help figuring out what it is will help.
thanks
scott
Old Nov 4, 2001 | 11:51 PM
bent70's Avatar
bent70
axle id
[font size="1" color="#FF0000"]LAST EDITED ON 05-Nov-01 AT 00:55 AM (EST)[/font][p]http://photos.yahoo.com/scottsbent70
Old Nov 5, 2001 | 09:26 PM
BigRebel's Avatar
BigRebel
axle id
hey, you have your self there a dana 61. regular dana 60 gears wont fit it but a regular dana 60 carrier will. it also has the big axle bearings so you could upgrade to 35-spline shafts no prob.
BigRebel (aka.Mike)
1985 Toyota 4 Runner, 22RE, SR-5, 5 Speed, 4.10 gears, 30x9.50 R15 tires, 198,000 miles and going and going....
http://home.off-road.com/~trailrunner
Old Nov 5, 2001 | 10:35 PM
bent70's Avatar
bent70
axle id
are there any lists to verify is a 61. Is it possible to run 5.13 gears or do I have to get special offset spool to run regualar 60 gears.
thanks
Old Nov 13, 2001 | 09:31 PM
unreng's Avatar
unreng
axle id
Old Nov 13, 2001 | 09:43 PM
BigRebel's Avatar
BigRebel
axle id
hey, i see that you are also on the PBB cool. any way you have to make a custom spacer 7/16 think to run regular gears or have sandy cone make you a 40 spline spool. any way the lowerest gear you can get for it would be a 4.56 ratio. hope this helps.
thundersnow70
18
Jan 5, 2014 08:19 PM
CowboyFromHell
23
Feb 25, 2009 08:37 AM
zooom
Jul 27, 2008 05:54 PM
69 F100 LWB
Apr 10, 2007 03:03 PM
