- New to the forum with a new truck!
- AC Compressor Removal - Not Service
- 1974 F250 FE 390 developed loud knock after header install?
- engine/idle issues
- Fan Shrouds Compared
- R 134
- Ford bed rail touch up
- Seals for 78 f150 4x4 front axle
- Shade Tree Mechanic
- items inside the heat core area.
- 1978 Ford Ranger F150 4x4 Shakes and clunks while in gear.
- Wheel alignment in Atlanta
- 1979 f250 rear leaf springs needed
- Correct parking brake pedal assembly for 1976 F250
- What changes have you made to your dentside?
- Oil in gas, new carb, new fuel pump, and now the timing chain has gone super slack.
- LA Area Mechanic - 1976 F250 4x4
- Original kick down linkage at carburetor
- wiring diagram?
- Front Axle Question
- Wire identification help needed!
- Fan shroud, yes or no.
- 1975 F250 Highboy Crewcab 4x4 Build
- Hood spring
- Rare 1968 F-250 Camper Special
- C-6 Transmission tube / stick ?????
- 1974 f250 build
- Driveshaft for 3 speed to np435 swap
- 1978 f250 4x4 rear super duty spring swap
- Cummins swap and tranny dilema
