- 79 f150 4.9 1bbl idles like crap
- Vin # question
- Junkyard Driveshaft?
- Distributor wiring
- Tail light wiring issue
- 351M Oil Pressure
- Timing Advice
- Fuel sending unit
- Need suggestions please, truck will barely run- UPDATE, FOUND PROBLEM
- At wits end: Runs great, no power on hills/4th gear
- No tailights no turn signals brakelights work headlights and front turnsignals flash
- very brief rod or bearing knock only on startup?
- The nut in the engine compartment
- 460 Engine Block Heater
- Is my 460 overheating because I'm missing the water pump backing plate?
- No harmony in my harmonic balancer
- [Transmission] C6 w/4WD
- Very Rare 1979 F150 Shortbox
- What to use to clean starter
- Any suggestions on rusty drip rails?
- OEM Style Bolts
- Why is my dash brown? Your opinions please.
- Where to find f600 parts?
- 351M - What is the dome with one wire attached behind intake manifold?
- HEI Ignition installed
- Was the 390 np435 avail in 1975 for an F100 4x4
- Tim's 1973 Dentside
- Bad Starter and cannot remove
- Clutch fork Slop at Bell Housing
- Two Quick question regarding reinstalling front coil springs and shocks
