Adjusting caster? Manuals says no, mechanic says yes...
I brought my 78 F100 2x4 to get aligned, but they couldn't fix the caster because they didn't have the tools. They said the left side caster was 5.8 and right was 4.6, but not to worry about it. Should I go to another shop and have caster adjusted? (They didn't remember what the ride height was, but my manual says those caster numbers are probably out of spec).
What I need to know is: The mechanics told me they can adjust the camber. BUT NOTE: Both my Ford manual and Chilton manual say my year F100 with I-beams CANNOT adjust camber and caster (only older models can). What gives?? Also, I don't need new springs, do I?
Is there anything else I should change before bringing it in? (I already replaced the radius arm bushings).
faype02(No Email Addresses In Posts!)
1978 F100 6-Cyl 300 3-speed 2x4
https://www.ford-trucks.com/dcforum/User_files/mil1ion/3be830b818a14a9c.gif
I had to replace my SPRINGS at one point so the wheel alignment could be done.
It's entirely possible ,how many miles on your truck?
Dennis
78 F-150 429CJ 465,000 KM.(Original Owner)
68 Mustang 289 Sunlit Gold 80,000 Miles(second Owner)
64 1/2,260 Pre-World's Fair Mustang #8092
64 Fairlane 500 S/C,waiting for a 390 4-Spd
If The Girls Don't Find You Handsome,
They Should At Least Find You Handy!
Dennis
[font size="1" color="#FF0000"]LAST EDITED ON 06-Nov-01 AT 08:03 PM (EST)[/font][p]Take a hard look at the rubber bushings that the radius rods go to under the cab mount. If there dryed out bad it alows the axle to move back a little and messes the caster.
44Dwarf
44Dwarf
Pete, There are still good tire stores around that can bend the I-beams and get you riding correctly again.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker
[link:www.ford-trucks.net/users/jowilker|Club FTE since 01 01] My FTE Page
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NC Truck Owners] NC Ford Truck owners group
66F100s Rule
In the cool still quiet of night you can hear chevies rusting away.
John
jowilker
66F100s Rule
fastang50
03-28-2023 10:48 AM
granny_rocket
22
12-02-2015 10:17 AM
AvdDrift
12-18-2014 10:04 AM
