- chassis lengths
- 18" wheels on the 70's trucks?
- wide vs narrow/small side trim differences.
- 1976 ford f-250
- Odd engine swap
- 460 HP/Torque & RPM's
- Changing Manual Fuel Pump
- Trans fluid amt/bulb
- any one want
- 1979 f250 Lift help
- vin code x
- Rough idle/stalling
- 460 Swap in 73 F100, I know its been covered
- Brake line size?
- Fuel Economy 360 - 300
- extra cooling radiator
- Upgrade Brakes??
- how much longer for the 73-79's
- 400cid developed a high speed/load miss
- freshend up the engine......
- will 80s ford tailgate fit on my 76?
- Column arm wobbly
- Do you ever feel like giving up? need motivation
- Cluster Question
- 78 rebuild
- No more smog stuff!!!
- Lost With Door Jam Switches?
- Drop pitman arms???
- venting down below
- steering column swap from 79 to 77
