- Drain plug over crossmember
- a/c compressor let the blue smoke out
- Valve stem seal size ? and overhaul update !
- New fans' control box
- Front end swap
- U Joint questions
- 1979 rear main
- Another cool tool is the insulation piercing test probe
- Tank switching solenoid and fuel line size
- Truck starts but...
- 2" Leveling Kit
- manual steering box conversion
- The Stove
- tee fittings
- Swap 3-on-the-tree to auto - what's needed?
- Newbie needing somehelp
- Why can't people just do things right...or how to remove overspray?
- 1979 ford short bed stepside
- about to take the plunge.
- Engine bay clean up
- ID the power steering hose.
- Parking brake release itself
- Steering/Suspension help near Houston?
- Restoration On A 79 SC F250 Initial Questions
- The most amazing tool - the distributor wrench
- if you were going to build an engine for a dent....
- hello all from a mile high
- Dana 60 swap?
- When the obvious is not the real problem...
- 1974 F100 w/360 fuel starvation problem
