- 390 in '77 Pulley help
- Rear end sound I can't identify
- Replacing floating rear drums
- Oil capacity question.
- Anyone have pictures of the 302 (standard shift) stock exhaust connections at manifold?
- 1976 F350 390 Air Cleaner Part Number?
- 1979 side window weather stripping kit
- 1979 F100 won’t idle
- NP435 question
- Dad's 73 Camper Special, needs direction
- ‘79 F100 Won’t Idle
- Anyone selling a set of these hubcaps?
- Is my 9 inch in good shape
- L and L problems
- I drive by this everyday, not mine
- 1979 F-100 Cab interior parts
- 77 HOS rebuild thread.....lots of pictures
- 2WD to 4X4
- Vin decode
- Sliding rear window
- LMC rear window gasket
- Plug for clutch rod opening
- '79 Headlight Switch (Rectangular to Round)
- Do I have ram assist or standard PS?
- Summit Carb
- Dakota Digital VHX for this generation truck
- Issues with an oil leak because of a small gap in between fuel pump and engine block
- 1977 F250 turn signal harness install issues!
- 351W EFI swap
- C6 slipping speedometer gear on tail shaft.
