- noisy electric fuel pump
- 390 oiling difficulties
- Clutch pedal NOT returning?? Ideas needed Please:)
- noise comming from heater
- oil plug leak
- Where do you carry your spare tire?
- Engine stumbles
- A Steering system Question
- 78 F2504x4
- HELP!!! Bed floor needed
- TIP - fix that old gauge cluster lens
- aftermarket A/C kits
- How hard is it to replace ball joints
- 400 running rough all the sudden help me!
- is dana 60 rear stock in '79 f350 4wd
- book for VIN# decoding
- vent window rubber, tucked or overlapped??
- fan shroud ??
- King Pin Ball Joints/ Front end shimmy
- lifter?
- New to board/Thanks already!!!!
- Setting the choke
- Frony hub/Brake Disc?
- Check out this - Red Skelton's truck up for auction
- Changing front seal on a dana 60 rear end
- body lift for a 78 2wd??
- how common is my truck?
- Vin Decode for 79 F150
- standard transmission to automatic
- where can i find a turbo charger?
