- 1975 elecrical conversion
- What are the Ford factory 16.5 x 9.75 steel wheels worth?
- WHEEL HELP
- Stripe kit question
- What is a quirk vs a real [fixable] problem??
- 60’s Bed on a 70’s truck?
- New to me F350 Super Camper Special
- Going Rate for a 1978 F150 4X4 SB Project Truck
- Radio slider assembly - spring location
- Am/Fm stereo radio
- Bed bushing replacement
- Tie Downs ... 6 or 10 bed top rail?
- Manual swapping
- Engine size
- Best door striker fix?
- New truck project
- Dual battery
- Pitman arm connection to tie rod
- 460cu: what alternatives are easy swaps?
- Simple wiring question
- Radio/antenna identify?
- Carb swap — 2150 to Holly 2300 0-80500
- CA Emissions strikes again... 1978 F-350 Camper Special
- 1978 f150 custom rusted frame
- valve cover breathers each side same or different?
- '75 460 engine lift plate bolt sizes?
- 79 F150 Pickup Cab & Radiator Core Support
- The Money Pit
- Window felts/sweeps questions
- Oil Gaurd protection
