- convert to standard
- Front End Problem Diagnosis-
- 2x4 to 4x4 conversion frame
- '78 supercab body
- Frame difference
- tube bumpers on 79
- bad ball joints
- Stronger 9 inch
- Do any of you have train horns on your trucks?
- 300ci Fan Shroud
- New member with 4wd conversion/frame questions
- transmission
- Just bought a '78 F150, I'm now looking for generic info.
- 70s model f350 4x4
- What would it take to tow 5-6000 lbs safely with an F-100?
- How Can I Identify Wich C6 to use in my 73 F250 4X4?
- Dually fenders
- Anyone installed a late model (88+) fuel tank in 79 frame
- radius arm
- replacing rear brakes hardline
- help with the fireing order
- Header trouble
- removing cab
- HD brakes '75 F-250
- no spark
- Idle's fine... dies in gear... any ideas???
- Mixed up gears
- new brake issue
- detonation/pinging problems 400m
- No A/C- options to add it?...
