Alternator upgrade
Old Nov 5, 2001 | 12:13 AM
Torque1st's Avatar
Torque1st
Posting Legend
Alternator upgrade
Old Dec 15, 2001 | 09:25 PM
jlasater's Avatar
jlasater
Alternator upgrade
Have any of you guys ever upgraded/swapped to a single wire alternator that is used in Chevies, eliminating the seperate regulator used in the Ford? Just eyeing a higher capacity alternator (140amp) that has an internal regulator. Can it be adapted to a Ford electrical system?
Old Dec 15, 2001 | 10:03 PM
Ozzie's Avatar
Ozzie
Alternator upgrade
Guys building their own rods do it all the time. Sure makes it easy when you're putting things where they don't normally belong. I believe you can use existing brackets, depending on the clocking of mounting ears on the one-wire you're using. I've dealt with a local auto electric shop who buys, converts and sells($50) the one-wire with a lifetime warranty. Will build to suit. Just run the cable from the post on the back of the alternator over to solenoid and that's it. Takes the voltage regulator out of the picture. Anyone more knowledgeable on this please correct me if I'm wrong, having not personally done this. Joe
Old Dec 16, 2001 | 07:37 AM
Chuck P.'s Avatar
Chuck P.
Alternator upgrade
If your looking at the PowerMaster, then yeah, I've had one for a couple of years now. This is on a 460 swap and only thing I had to do was obtain a 2" shorter belt. You will need to keep one wire from the the stock reg. if you have the light on the dash like I do. Don't think you need to do anything if you have the gauge. You also have the option of running an extra wire so the field is "hot" all the time. This may be needed if you have a very low idle rpm. I left the old wiring in place so if the need arises for a spare/replacement I can just plug the old one back in and be on my way.
Old Dec 16, 2001 | 10:20 PM
Matt67's Avatar
Matt67
Alternator upgrade
I was about to post the same question.
I would realy like the simplicity of a one wire altnernator. I wouldn't think it would be to hard to fabricate brackets, but I've never seen a GM alternator up close. I've seen these Tubes that you trim, to bolt the alternator to the head where there is a tapped hole, for chevy's, but they might be good for this.
This would make a good tech article.
Anybody, please help us out!
P.S. would different engines need different brakets? I got a 302.
Old Dec 17, 2001 | 04:15 PM
otto's Avatar
otto
Alternator upgrade
ford alternator wiring is so easy to troubleshoot I wouldnt dream of converting, You can buy one wire alternators that use fords rear terminal EVR case from summit, or have any auto electric shop rewind yours for high output and convert it to one wire for the price of the delco alt
Old Dec 18, 2001 | 06:34 AM
William's Avatar
William
Alternator upgrade
Convert to a early model GM 85 amp alternator. I did this swap a couple of months ago and encountered no major problems. I also wrote a "how to" technical article that Ken has not published. I will e-mail you the article if you want it. It is to long to post here.
William in Atlanta
Old Dec 19, 2001 | 08:01 PM
Matt67's Avatar
Matt67
Alternator upgrade
William,
send it too me please. Make sure the Subject on the e-mail says somthing about Ford, cause I delete everything I don't recognize... Been getting a lot of junk e-mail.
Old Dec 20, 2001 | 07:07 PM
mk's Avatar
mk
Alternator upgrade
The latest issue of Street Rodder magazine has a good article on single wire alternators.
Old Dec 21, 2001 | 11:55 AM
beartracks's Avatar
beartracks
Alternator upgrade
One thing to know about single wire alternators. As a general rule they do not charge very well at idle. For that matter neither does the stock Ford with seperate regulator. Also have seen the same thing with stock Ford alternator upgrade kits. Made the idle problem worse.
Bear
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
