zf 5 speed
Old Dec 30, 2004 | 10:23 AM
blu's Avatar
blu
zf 5 speed
New ZF 5 Speed Transmission Less Than 1500 Miles & Transfer Case, Out of 88 Ford F350 4x4 w/460, $300 OBO.
Just saw this in the local paper and the first thought i had was to replace my C6 to much work probably....
Old Dec 30, 2004 | 12:09 PM
DannyP's Avatar
DannyP
The 460 ZF will not bolt up to the Ford diesels unless you change the forward half of the tranny case. If the stated miles are right it's a good deal though.
DannyP
Old Jan 3, 2005 | 06:26 AM
Reese Moody's Avatar
Reese Moody
I just did this same thing. I had to purchase a core transmission from an auto wreckering co. $275.00 in Oregon. Make sure the core is from a 7.3 or 6.9.. I put a 6.9 in a 88 F-350 w/460 ZF 5 speed. I ran into clutch problems ( excessive growling ) had to get a LUK fly wheel and clutch kit $785.00 to deal with different cluches between 87 and 88. If you truck is 88 or newer, you won't need the kit. Swapping tranny housings is not to bad, you do have to pay attention though start with the front of the tranny down on 2x4 blocks standing straight up. Once you split the case you will be able to figure it out. And dont forget to remove the detents, or it won;t go back together. You can also take both tranny's to AMMCO $400.00. Sounds bad but it is well worth it. I love mine.....Reese
714x4
Jul 27, 2010 03:09 PM
patsplace
Mar 1, 2005 12:12 AM
gkovakas
May 26, 2004 07:11 PM
fordmudrunner2020
Jul 16, 2003 08:57 PM
