- No Oil Pressure/1986 F250 460ci
- 1996 460 EFI Tune up/ Timing question
- 460 miss
- Oil Filter Comparison
- 69 429 Thunderjet
- rough idle, 88 F350 460 EFI w/new idle control valve
- Ford 429 CJ buildup
- '87' 460efi hard cold start Help?
- '88 460 Backfiring
- Recommended Timing Chain????
- 460 carb ??
- Best water pump for '87 460?
- HP & Torque Expectations 460
- Offy 360 manifold
- electronic ignition system conversion 460
- 1996 460 need help picking out some mods.
- Valve train noise or worse?
- hp gains in 460 from porting heads/porting intake manifold???
- What do they mean open the plenum up on the intake?
- Diesels sometimes after shut off!
- EGR Valve and other pollution control stuff
- Cranking compression for stock 460
- F3TE heads are almost done, need a little expert advice...
- Rough Idling Caused By Bad Lifters?
- wrong timing set
- 460 Oil Pan questions
- 460 spark plug wires
- a little exhausting help here
- Need legal smog carb for '85 F-250 -- What are my options?
- 1977 460 Valve Cover Torque Specs
