wrong timing set
Old Aug 20, 2005 | 12:20 AM
Powergod's Avatar
Powergod
Question wrong timing set
my friend and I just threw a 460 together for a 4X4 jamboree and I think we used the wrong timing set(gears and chain). We put the timing set from a smog motor on our non smog motor. Does this affect anything badly. Heard that it will retard the timing a lot and not run as good. I thought that it would have more power than it does and was wondering if this is the problem. Thanks for the help.
Old Aug 20, 2005 | 11:02 PM
wtroger's Avatar
wtroger
Worst case is the valve timing will be retarded 4 degrees.
