electronic ignition system conversion 460
Old Aug 24, 2005 | 01:42 PM
olfordsnstone's Avatar
olfordsnstone
I have a 68 460 lincoln engine in my 74 F250 4x4. Could someone guide me on what would be the best avenue to convert to an electronic ignition. I have been told that other late 70's and early 80's ford engines have an ignition that would work. Any guidance would be greatly appreciated.
Thanks, Tim
Old Sep 17, 2005 | 11:23 AM
beaners1's Avatar
beaners1
I put a 75 T-bird 460 in my 86 F-150, used all the trucks original ignition system and it runs fine off of it.
Old Sep 17, 2005 | 02:38 PM
monsterbaby's Avatar
monsterbaby
basically you could pull the ignition out of a late 70s ford truck with say a 351m/400 including dist since it uses the same dist as a 460, and will drop right in, and get teh ingnition box, and personally I would grab as much of the wiring harness as i could.
Old Sep 19, 2005 | 02:15 PM
William's Avatar
William
For a hundred bucks you can get a new HEI distributor off e-bay. One wire drop in deal, coil in cap easy as pie.
BGF100
Oct 15, 2016 09:58 AM
eladnermai
Nov 23, 2012 02:04 PM
iwals
May 23, 2011 07:53 PM
mla
Feb 1, 2009 09:51 PM
cpt_insano
Mar 28, 2002 12:16 AM
