- 391
- Where is my ballast resistor?
- Marine 427 the good and the Bad
- From a 240/3speed to a 390/C6
- push rods
- How unusual is it for a timing chain to skip?
- Track update!
- block ID
- Goin' Racin'
- Suggestions on Building Heads
- What are these heads...any good?
- Which will make more power?
- What's your 0 to 60 time?
- 428 ?
- Still Backfiring.
- Quick Question
- Remove pass side engine head
- where to get headers
- Porting heads
- 750HP, 428 FE powered fox body 'stang
- Brake booster port
- oil flow at rockers
- 427 CAMMER
- standard to high volume swap completed
- Bad rocker?...or bad lifter?
- flywheel bottoms out on bellhouse
- Diesel Swap
- boring out FE for more hp
- Hey BigBlue- where did/do you get FE Nitrous
- Is it possible???
