Old Jul 8, 2002 | 09:11 AM
fordguy76's Avatar
fordguy76
whats the visual difference in the FT's and the FE's? i know the crank is different but how do you tell from the outside?
Old Jul 8, 2002 | 11:46 AM
Ratsmoker's Avatar
Ratsmoker
391
Well there is a tag on the engine usually that will say 391 etc.. There will not be a 352 ususally on the left front of the block just below the head. The main webs are reinforced and there is usually much more meat in the cylinder walls. The distributor hole will be too big for an FE dizzy unless you buy a bushing for it. The heads have smaller ports and they are always 4bbl engine I do believe.
Old Jul 8, 2002 | 12:03 PM
fordguy76's Avatar
fordguy76
thanks man. im going to look at what i was told was a 390 tommorow. its in a big tanker truck and i dont think they ever put 390's in that big of a truck. i think it is a 391 more than likely. which would you rather have?
Old Jul 8, 2002 | 04:23 PM
jowilker's Avatar
jowilker
Seth, It's a good chance that a 330 is in the truck also.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
Old Jul 8, 2002 | 06:22 PM
FEina52F1's Avatar
FEina52F1
391
[updated:LAST EDITED ON 08-Jul-02 AT 07:23 PM (EST)]>whats the visual difference in the FT's and the FE's? i
>outside?
the size of the pulleys and crank snout
the cylinder heads
the water pump and the timing cover
are very different
Old Jul 8, 2002 | 07:18 PM
FE427TP's Avatar
FE427TP
391
weren't the FT's mounted with a block plate instead of the regular motor mounts too? and had a oil line for the air compressor.
Old Jul 9, 2002 | 10:18 AM
fordguy76's Avatar
fordguy76
didn't the FT's have steel cranks? what parts will fit off a FE? the guy said it ran 5 years ago when he parked it. im wondering why he parked it. he says its a 390. i'll look at my grandpa's 330 before i go and then look at a 360 and note the differences.
Old Jul 9, 2002 | 11:36 AM
Ratsmoker's Avatar
Ratsmoker
391
The cranks were all steel and you can use them by grounding the snouts down and re keying them. I beleive they are balanced differently (externally) but I may be wrong. Almost all parts are interchangeable. But there are things like an FE intake would not work well with FT heads becasue of the differences in port sizes.
Old Jul 9, 2002 | 02:14 PM
fordguy76's Avatar
fordguy76
i looked at the 330 and the 360 my grandpa has. the crank snout is way bigger on the 330. the 330 still has 352 cast on the block and has a 2bbl carb. it has 3 engine mounts. 1 in front and 2 on the back crossmember. it has y-type exhaust manifolds like a ch*vy or some Y-blocks. now i will know what to look for. would stock heads off a 360 or something be better than the heads on the FT?
Old Jul 10, 2002 | 05:41 AM
karljay's Avatar
karljay
391
I can't think of any FT heads that would be good for a street/performance engine. The standard 360 heads would be C8AE-H or D2---- heads and both are plentiful and can be made to work excellent on the street. If you change heads on the FT to the FE heads, you'll want to change the intake too as the exhaust crossover is located in the center on the FT and on the sides on the FE.
One nice advantage to the FT is the block, the block is supposed to be boreable to 4.13 (428 size) and stronger that a stock FE block.
Old Jul 10, 2002 | 09:46 PM
fordguy76's Avatar
fordguy76
went and looked at it and it was a 391. had a four barrel intake, dual thermostats, and big pulleys. i went ahead and bought it and brought it home. i'm going to rebuild it with FE heads and a edelbroc intake. maybe a mild cam.
thanks for all the replys
will the FT dist. fit in through the FE intake hole
Old Jul 10, 2002 | 10:44 PM
Ratsmoker's Avatar
Ratsmoker
391
The FT dizzy will not fit in an FE but with a bushing that can be bought from ford the last I checked you can run an FE dizzy in an FT block. My block has the FT size hole for the dizzy and the FE bushing. Good buy and good luck!
Old Jul 11, 2002 | 08:44 PM
fordguy76's Avatar
fordguy76
how much was the bushing? what did you ask for when you got it? and will a FE crank fit in the FT block?
Old Jul 11, 2002 | 09:18 PM
Ratsmoker's Avatar
Ratsmoker
391
I have a 1974 casting which was actually an FT block converted to an FE. Most all FE's were like this from 1973 - 1976 so I did not have to buy mine because it came from the factory with one. You can slap an FE crank in an FE block without any problems whatsoever as long as you have the FE balancer, pulley and flywheel.
Old Jul 12, 2002 | 11:56 AM
zobcity1's Avatar
zobcity1
391
The block has little ribs on it and by the side soft plugs by the oil pan/ block mating surface. There may be more though I cannot tell.
Rob
