Remove pass side engine head
Old Jul 1, 2002 | 10:53 PM
paulbunyan's Avatar
paulbunyan
All,
I broke off one of the exhaust manifold bolts on the pass side, argghhhh. I am preparing myself to pull off the damned head and drill the bolt out. I have never replaced ANY automotive engine head before, but I am pretty sure I can figure it out. I have a Haynes book right here. It seems simple in theory. Take the intake and carb off as one assembly. Pull the rocker arm covers, pull the rocker shaft assembly, pull the rocker arms, and then pull the heads. The rocker shaft assembly is the main thing that may give me some trouble. Does anyone have any advice or know a good book I can purchase on rebuilding 360/390 engines? I don't plan on rebuilding it just yet, but I know a book like that should have more pictures, etc for our engines. Thanks,
Paul B
Old Jul 1, 2002 | 11:32 PM
Mil1ion's Avatar
Mil1ion
Make sure you keep all the parts in their special order.
You can drill holes in a yardstick or other opiece of wood to hold the pushrods IN ORDER >front to back.
Keep the rocker arms in Order too > Label them to the match the pushrods<
The head is very heavy > Make sure you have physically *stretched first* and be careful lifting it off. Don't Hurt Yourself with twisting and lifting wrongly.
Have a site prepared to lay it on before removing it.
If YOU are doing it >When drilling out the bolt have the correct type of Drill Bit for this use be careful to center it before drilling.
[font color=red]Dennis
FTE Adminstration
[/font]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
[/font]
Old Jul 2, 2002 | 01:11 AM
karljay's Avatar
karljay
Ditto on the bolts and push rods, they MUST go back the exact way they came out. The rocker arm shaft has 3 different types of bolts, long necked down, short necked down and standard for the ends. The long necked down must go back into the oil feed hole. Remove the bolts 1 turn each to release the tension evenly.
As for books, I think "how to rebuild big block fords" is the best. I think this site here sells them. Check some of the links on the main page or search the 'shop now' in the upper right corner.
Old Jul 2, 2002 | 06:15 AM
DailyDriver's Avatar
DailyDriver
I'll give that a big second. The intake is no bag of feathers either. What I did with my 390 is take the hood off. Then that allows you to climb on, centered over the top of the engine to get a good lift with your legs and not your back. Your not reaching. You can sit right on the fender to pull the head. This will also help you with installing the manifold as it can be difficult to get it set just right. There have been some on this board that have said using the cork end gaskets are not necessary if you use silicone, and have done so with success. Me, I used the cork and climbing on top of the engine helped me to set the manifold right without messing up the gaskets. And it can be very easy to get them messed just a little to give you a vacuum leak. Removing the hood may be an extra step but worth it in the long run in my opinion. But it's your call. Good luck.
Old Jul 2, 2002 | 10:21 AM
paulbunyan's Avatar
paulbunyan
All,
Thanks for the tips, especially about the hood. I still don't know if I'll pull mines off, but that is the type of hint that will save me a lto of time :-) As far as the pushrods, I got some old shoe boxes that I plan on punching holes in and sticking the pushrods through. I was thinking that I could place the rocker arm, the nuts, etc for it in a bag and tie it to the pushrod and stick the pushrod into the top of my shoebox. Does that sound feasible to any of you guys? I ordered the How to rebuild big block Fords book from Amazon last night right after I made the first post. Are there any special tools I might need?
Paul B
Old Jul 2, 2002 | 10:23 AM
paulbunyan's Avatar
paulbunyan
Oh yeah,
I just had to drill out a bolt on my 1997 Mitsubishi galant, I still have the Nut extractor set from Auto Zone. It only costed like $14.99 I think, worked pretty good on the Galant. It comes with extractors and bits. I wouldnt mind finding a left threaded drill bit somewhere though...
Paul B
Old Jul 2, 2002 | 12:00 PM
Ratsmoker's Avatar
Ratsmoker
Another tip for removing the head. Don't stick large handles in the intake ports to pry it off. Also you don't have to beat on it. There are two grooves on the bottom of the intake side of the head. They are there for a reason. Stick a big screwdriver between the heaad and the gasket there and give it a whack. Be sure to have a catch man cause they fall fast.
Old Jul 3, 2002 | 08:36 AM
paulbunyan's Avatar
paulbunyan
Ratsmoker,
Do I have to worry about gouging the head if I pry it up on those grooves??? I would think not, but I just wanna be sure. I don't want to ruin my head the first time I ever try to pull one off lol
Paul B
Old Jul 3, 2002 | 08:38 AM
paulbunyan's Avatar
paulbunyan
All,
I just remembered, the owner said this truck was a 390 .090 over lol. While I got the head off, is there any sure fire way to see if it has been bored over at all and if so how much? Is there anything else that I can check while I have the head off? Thanks guys.
Paul B
Old Jul 3, 2002 | 11:27 AM
Ratsmoker's Avatar
Ratsmoker
If you are really paul bunyan then you might gouge the heads but a normal man with a normal screwdriver would probably have to try pretty hard. Once the head is off remove any carbon from the center of the piston and look for a number. If it says 30 anywhere wether it is .030 or 30 then it is .030 over. If the piston is blank usually (not always the ppistons are original or stock size. A micrometer would then be needed to determine the bore for sure.
Old Jul 3, 2002 | 02:18 PM
paulbunyan's Avatar
paulbunyan
Ratsmoker,
LOL@Paul Bunyan, im big but not that strong :-) Anyways, yeah I will definately check the top of the piston out. What should I use to get the carbon off? I can't wait for that Big Block Ford book to get here so I can get started. I have all the tools (no hoist) but I think Im gonna venture out and try to take the hood off to make it easier. That's one thing I can figger out without the book lol
Paul B
Old Jul 3, 2002 | 05:04 PM
Ratsmoker's Avatar
Ratsmoker
I used a rotary wire bruch that goes into the end of a cordless drill. Make sure that the piston is at the top of the block when doing this and make darn sure you clean up the mess.
Old Jul 3, 2002 | 05:06 PM
Ratsmoker's Avatar
Ratsmoker
As far as the hood goes you can take it off but I see no reason too. It really isn't that hard to do and messing with the hood may just take longer. Just have a friend handy.
Old Jul 3, 2002 | 07:08 PM
Mil1ion's Avatar
Mil1ion
>Ratsmoker,
>Paul B
If it fits great right now,don't forget to scribe the hood at the hinges to allow for exact attachment when you put it back on.
FTE Adminstration
[/font]
[/font]
Old Jul 3, 2002 | 08:33 PM
Like M. Fords's Avatar
Like M. Fords
Isn't it possible to remove the head without removing the intake? We had a friend change a head gasket on one of our truck's 390 this way. Sure surprised the heck out of me. He had the job done in less than 2 hours. Nothing to loose--worth a try! If it works, you will have an extra intake and valve cover gasket left over for the next time.
