- Single/Dual plane
- High Output 360?
- Does I.M have to be removed to take heads off?
- check this out!!!!
- block casting #
- Can I use 360 rods and pistons in a 390?
- FE446 power issue, MSD stuff.
- Erson TQ40H: hotter alternative to the Crane 941?
- dual vs. single pattern cams
- 13'' of vacuum
- $100 390
- Is a 460 an FE?
- 71's stock 360 to 427, how?
- engine swap
- Preferred pistons
- off-the-shelf cams
- Blown 412
- Made it! Still knocking....
- carb gaskets
- 3X2's Idle
- oil pump shaft problems
- best muffler
- 360 starter question
- 390 or 360
- Part throttle pinging
- buying performer package a mistake????
- fuel pump thing
- Exhaust pipe size to headers Q?
- Weight of stock FE 360 intake.
- Flywheel and Oil questions
