oil pump shaft problems
Old Sep 27, 2004 | 03:23 PM
fpbIII's Avatar
fpbIII
what did i do wrong? I'm rebuilding a 352 engine and for some reason the oil pump shaft is too short. the new and old shaft are both too short. did i buy the wrong oil pump?
Old Sep 27, 2004 | 03:34 PM
gtex's Avatar
gtex
What pump did you buy? I've never heard of this problem before. A lot of us run the Melling HV57, high volume pump.
Does the pump look like your old pump?
I reccomend the ARP pump shaft. I've twisted a Milodon.
Old Sep 27, 2004 | 04:56 PM
Scouder's Avatar
Scouder
I've never heard of different shaft lengths in FE engines. I've always been under the impression that "one size fits all". Something is wrong. What part number is the new pump? How did you find out that it was too short?
-Scouder
Old Sep 27, 2004 | 05:00 PM
Mike G's Avatar
Mike G
Did you drop the pump shaft into the motor from the top side and the ring is holding it up? The shaft need to be installed from the bottom of the motor, then the pump.
Welcome aboard! --Mike
Old Sep 27, 2004 | 05:48 PM
fpbIII's Avatar
fpbIII
the new pump looks exactly like the old one. the new shaft is from arp and is the same length as the old one. i believe now that i've installed the shaft wrong due to the reply from Mike G. i did drop it in from the top thinking that the ring on the shaft was there to hold it up so the distributor could slide over it. this weekend when i go home from college i'll try to install the shaft according to Mike G. thank you all for the info.
Old Sep 27, 2004 | 06:11 PM
Scouder's Avatar
Scouder
Good job Mike! I would never have thought of installing it from the top as being the problem.
-Scouder
Old Sep 28, 2004 | 02:38 AM
ilikefordtrucks's Avatar
ilikefordtrucks
are you sure its too short, or the wrong diameter, i ran into this in my 352. bought an FT oil pump by mistake, had to get a shaft machined by a guy in town, but it works fine, had me goin' for a while though
Old Sep 28, 2004 | 09:43 AM
debestuss's Avatar
debestuss
LOL, you guys are awesome.
Old Oct 3, 2004 | 08:10 PM
fpbIII's Avatar
fpbIII
it worked, i put the oil pump shaft in according to Mike.G and it fit.
AAubinoe
Modular V8 (4.6L, 5.4L)
Sep 1, 2016 05:53 PM
Colberding
May 2, 2016 09:38 PM
Colberding
Aftermarket Products
May 2, 2016 08:43 PM
JohnJohn13
Mar 17, 2016 01:13 PM
BigDoug
Nov 22, 2014 04:35 PM
