High Output 360?
Old Oct 1, 2004 | 11:08 AM
SuperFord's Avatar
SuperFord
High Output 360?
Were there any high output or special 360 engines used in the F-Series. I have a 71 F-250 4X4 with a 360 2bbl that has been in the family. Recently my uncle told me that in it's day, it was the fastest truck he had ever driven. Why would this be? I have not been able to drive it yet(Body Cancer). Is this a special motor, are all 360 just fast, or does he not know what he is talking about? Thanks.
Old Oct 1, 2004 | 11:14 AM
EgoMan's Avatar
EgoMan
There is nothing special about it other than its a ford. Its just a good solid design....and at that time all the other trucks were probobly just turds running small blocks. My 360 still amazes me and some other people too that thought that it wasnt big enough to be quick.
Old Oct 1, 2004 | 01:04 PM
rusty70f100's Avatar
rusty70f100
Those 360's did go pretty good. I know mine does.
Old Oct 1, 2004 | 01:57 PM
mswift's Avatar
mswift
I thought about putting my 360 in my boat......FOR AN ANCHOR!
Just foolin around. The 360 is a good solid motor. Afterall, it is a FE......
Mike
Old Oct 1, 2004 | 02:59 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
The 360 I had in my '74 was a torque monster - no problem going through mud up to the tops of the 33" tires in stock trim (3rd gear on the 435NP and 4LOW on the 205NP).
My brother who bought it brand-new said he had it up to 120 a few times - must have been 6000RPM being it had no overdrive - I think he embellished
My 390 would spin the tires too much - nice show, though
Old Oct 1, 2004 | 03:34 PM
michaelbrainardatwor's Avatar
Mike
All you need is the intake manifold! You could use it at Party Cove at the Lake of the Ozarks, and hold at least 20 boats! :
Old Oct 1, 2004 | 03:39 PM
EgoMan's Avatar
EgoMan
You must be mistaken with one of those 460's or windsors.....Better yet you must be thinking of a chevy.
Old Oct 1, 2004 | 03:44 PM
I have yet to figure out why Mercruiser ( and Volvo-Penta ) use only Chevy blocks for their powerplants... I do like the fact that Mercruiser is getting 1100 hp out of a little 557ci chevy big block... Even has a Warranty!!!
What does the Mazda kid say? ZOOM ZOOM?! F-in right!
taken from www.mercurymarine.com/1075sci
Specifications
HP: 1075
kW: 790
Full Throttle RPM Range: 5600-6000
Displacement Liter/CID: 9.1/557
Bore & Stroke (in): 4.50 x 4.375
Bore & Stroke (mm): 114 x 111
Compression Ratio: 8.00:1
Cylinders: V-8
Alternator Amp: 65
Alternator Watt: 917
Ignition System: PCM 03 Distributorless
Fuel System: Sequential Fuel Injection
Fuel Requirements: 91 Posted Octane (R+M)/2 (98 RON) International
Transmission: Huber 1450 Series
Drive Unit: Dry-Sump Six Drive
Gear Ratio: 1.15:1, 1.24:1, 1.35:1, 1.42:1, 1.50:1 or 1.61:1 (right- or left-hand)
Length (in/mm): 55/1397
Width (in/mm): 40/1016 (w/CMI Exhaust System)
Height (in/mm): 30/762
Weight (lbs / kg): 1720/782
Warranty: 90-day limited for recreational boating
Old Oct 1, 2004 | 03:46 PM
more specs:
Key Features
Designed and developed by Mercury Racing Engineering.
Handcrafted in Mercury Racing's four-cycle Race Shop.
557-cubic inch tall deck cast iron cylinder block featuring five main bearings with stud fastened steel main bearing caps.
Twin-screw Lysholm super chargers require less power than traditional single-screw roots blowers.
Super chargers feature closed lubrication with sight plug for added protection and enhanced durability.
Super charger induction noise levels are controlled by twin carbon fiber Helmholtz air inlet resonators.
Twin flame arrestors act also as air filters, keeping the engine's air induction system clean and efficient.
Eight ignition coils, one per cylinder, eliminates spark plug fouling.
The SmartCraft PCM 03 controller continuously monitors the amount of boost needed to provide consistent 1075 horsepower in any condition or environment and varies boost accordingly.
The SmartCraft PCM 03 microprocessor optimizes fuel, spark timing and knock control for each cylinder independently, enhancing engine running quality, performance and durability.
An all-new, high velocity cooling system uses a combination of a circulating pump and sea pump to keep the engine at an optimal operating temperature and peak performance.
Innovative dry-sump engine lubrication reduces friction and adds horsepower for improved overall boat performance.
Balanced steel crankshaft.
Forged-steel, 100%-machined connecting rods and custom Mercury Racing aluminum pistons.
High performance roller camshaft.
CNC ported, race-prepared aluminum cylinder heads.
Mercury Racing developed sealing systems, enhance engine durability.
High-performance electric fuel pump.
65-amp (917-watt) charging system.
Features the dry-sump Mercury Racing Six drive.
Six drive features innovative dry-sump lubrication system improves horsepower and overall boat performance.
Drive-line and plug-in models are available.
Available in right-hand and left-hand rotation models with 1.15:1, 1.24:1, 1.35:1, 1.42:1, 1.50:1 or 1.61:1 gear ratios.
Old Oct 1, 2004 | 03:47 PM
Sorry to BS all of you with marine engines...just thought you might find some interest in it...one guy mentiones anchors and boats and there I go!
Old Oct 1, 2004 | 04:15 PM
Chris Nikirk's Avatar
Chris Nikirk
My '67 F100 LB with a 360 and 4.11s in the rear feels scary fast off the line, but runs out of breath about 55mph. That could be part of the story is the torque and gearing in some of these trucks.
Old Oct 1, 2004 | 04:38 PM
krewat's Avatar
krewat
Chevy is the only manufacturer that will supply blocks with brass freeze-plugs
Or maybe the only one that will supply a complete long-block in marine trim?
Look at it this way - the way boat motors go (especially in salt-water), wouldn't you like to have a CHEAP Chevy instead of a slightly more expensive Ford ? That way when you blow or rot the darn thing every 2-4 years, it's cheaper ... more cost-effective...
Old Oct 1, 2004 | 05:01 PM
rebocardo's Avatar
rebocardo
I thought it had more to do with who can supply a reverse rotation motor for left and right hand drives.
Old Oct 1, 2004 | 05:08 PM
krewat's Avatar
krewat
There were 351/302s w/reverse rotation, no problem - change the cam and dizzy gear, and I think the small-blocks don't even have a rear-main seal problem with reversed grooves (like the marine 427's).
Old Oct 3, 2004 | 09:14 PM
rusty70f100
You know, I really think that cast 2 barrel might work good for holding a john boat. Just hook the rope through one intake port and away you go!
