- Intake Questions
- Tapping Lifters
- RPM intake
- FE446 tranny removal...
- valve keepers
- 390 ignition and carb
- rod bearing replacement
- timing and carb settings
- key things that should be noted
- Points Gap?
- Oil fouling plug with 150 lbs Compression
- New cam and lifters are in! Wooohoooo!
- 105 cast backwards on clock
- Victor 15166 is to big
- Bear I need some help
- Headers?
- Q Code?
- Edelbrock or stock ?
- bucking under light load
- Pushrods
- Well I measured the offset on my 10" Wheels
- happy memorial day...
- Air pumps?
- O/T GOOO Danica!!!!!
- engine externally balanced?
- It's OK for the Project to be a Project now (new ride) :-)
- coolant leak from dust pan
- setting point dwell
- Final Aproval
- Hey Highboy 74...
