valve keepers
Old Jun 2, 2005 | 11:26 PM
70_f100's Avatar
70_f100
valve keepers
Is there an easy way to remove valve keepers? I have a good valve compresser, is there another tool needed to remove the keepers? The last time I saw it done, they would pick right out with a magnent. What am I doing wrong?
Old Jun 2, 2005 | 11:30 PM
rusty70f100's Avatar
rusty70f100
If you compress the valvespring straight down, far enough, you should be able to pull 'em out with your fingers. Kind of turn 'em a bit on the valve and they'll come right off. Just make sure the spring compressor doesn't slip while your fingers are in there!
Edit: The keeper retainer has a tendency to stick on the keepers. You might need a small piece of wood, and a hammer, to dislodge it.
Old Jun 3, 2005 | 01:19 AM
ford390gashog's Avatar
ford390gashog
just pop them straight off the shaft.
Old Jun 3, 2005 | 05:48 AM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
What I use is a Mallet (a Dead blow) to smack the tops of the valve spring retainer's with a couple of times before using the spring compressor on them.. That usually breaks the keepers away from the Valve and they come off without any problem!!
Good Luck!!
Russ
hlmags13
Jul 29, 2013 11:30 AM
Boss50
Dec 12, 2009 04:43 PM
crescentwrencher
Jun 2, 2008 08:45 AM
dustinleavitt2000
Jun 7, 2003 11:16 AM
Irondale90
Sep 26, 2001 07:22 AM
