- IP Problem?
- Diesel Kleen in a gasser?
- swap???? need advice
- intercooler info needed junk yard options
- dps performance customer service
- wantin a turbo and overdrive
- Ho Ho Ho
- 6.9 using water
- vacuum line to turbo?
- more fuel to the 6.9 help needed
- 87 6.9 wont will start wont stay running!!!
- Not enough heat
- 6.9 injector-84 model
- Just picked up my first TD truck and have a slight problem.
- Starter motor Relay
- where to buy a new fuel sending unit
- cheap diesels on colorado craigslist
- truck won't stop starting
- Zd-9
- Fuel ?
- 5" strait pipes
- SAE 30 weight oil in fuel for lube?
- adjusting boost?
- Truck died, switched tanks and started up again....?
- antifreeze
- best injection pump
- Gaskets?
- average life of 7.3 turbos
- Ticking sound
- 86 6.9 will not start
