Not enough heat
Old Dec 24, 2007 | 07:58 PM
BIG R's Avatar
BIG R
Not enough heat
My heater is only working on the low selection, asked a local mechanic about it and he said it is probably the heat resistor, does this sound right or is it something else. If it is the heat resistor could someone be kind enough to tell me where it is located, and how hard it is to change out. Thanks again.
Old Dec 24, 2007 | 08:50 PM
Franklin2's Avatar
Franklin2
It's located in the duct work, mounted under the hood.
Old Dec 24, 2007 | 08:56 PM
David85's Avatar
David85
Are you referring to the fan switch? Usually when those fail they only have power in the high mode. I think the switch itself may be your problem.
The resistor it located at the heater case under the hood. Its near the bottom of the forward face of the box, held in by two screws.
Old Dec 24, 2007 | 09:16 PM
BIG R's Avatar
BIG R
Is this a cheap part, should I take a chance and replace it? When you say switch itself, do you mean the one on the dash? Don't mean to sound dumb, just do not know alot about this. Thanks
Old Dec 24, 2007 | 09:53 PM
David85's Avatar
David85
The switch is in the dash, right at the other end of the lever for the fan control.
Don't have a price for a new one, but I would expect they are both fairly cheap, your best bet is probably a wrecker though, I don't think you can get these parts at an autoparts store.
Old Dec 24, 2007 | 11:51 PM
roamer37's Avatar
roamer37
blower motor resitor assy is what controls the power to the blower motor the only time it is not used is on high where it gets full voltage.. the resistors fail a lot pretty common.. the connector to it could be melted as well..
Old Dec 25, 2007 | 08:38 AM
fonefiddy's Avatar
fonefiddy
Try cleaning the contacts on the blower resistor. Is common for them to get corroded and fail to make good contact.
Old Dec 25, 2007 | 12:40 PM
Franklin2's Avatar
Franklin2
The blower motor resistor is available from the parts stores. I agree though, that when it fails, you usually have high speed only on the fan motor.
We just fixed one on a 94 f350. It had high speed only. We took the resistor out, and everything looked ok, except there was this little cylinder type thing mounted on the board, and it did not have continuity. We finally figured out this was a thermal safety device, just like the ones they have in coffee makers. It opens up if things get overheated. We bypassed it will a piece of solder, and it worked. We were thinking if things got hot again, that possibly the solder would melt and shut things down. The only scenario I can think of when this safety thermal device would be needed, is if the bearings in the blower motor would lock up, so there still would be current going through the resistor network, but there would be no cooling air flowing over it. I have had them out while the fan was running, and the speed resistors get red hot.
Old Dec 25, 2007 | 08:18 PM
BIG R's Avatar
BIG R
I guess I will go ahead and change it out, advanced auto has it for $17.99. If that don't work I will probably be asking more questions. Thanks for all the advise.
