IP Problem?
Old Dec 26, 2007 | 04:52 PM
TurtleRacing's Avatar
TurtleRacing
PSD Addict
IP Problem?
I just changed my sons fuel filter and didn't fill it with DK, the truck started for a couple seconds then stalled, now nothing. We cracked the lines at the injectors and nothing is coming out of them, no fuel, I even took one off the injector and there is no fuel flowing. Is his IP bad?? Any suggestions?
Old Dec 26, 2007 | 05:52 PM
fellro86's Avatar
fellro86
You need to bleed the fuel filter. If you didn't fill the filter with anything, you are going to be cranking for a bit to get it filled. You may be further ahead to take the filter back off and at minimum fill it with fuel....
Old Dec 26, 2007 | 06:17 PM
TurtleRacing
PSD Addict
Well, there's no more air coming out of the shrader valve, should i still take the filter off and fill it?
Old Dec 26, 2007 | 06:28 PM
fellro86's Avatar
fellro86
Nope, you got it cleared, but keep the injection lines cracked, you are getting there... If you put nothing in the filter, there was no way the motor was going to keep going. I've even had them die like that with fuel added to the filter, just have to purge and it will be fine.
Old Dec 26, 2007 | 06:40 PM
TurtleRacing
PSD Addict
Thanks, what concerns me is there's no sign of anything coming out of the fuel lines.
Old Dec 26, 2007 | 06:42 PM
fellro86's Avatar
fellro86
You had to get the filter filled first, then it has to get worked though the IP. It doesn't come through in large amounts, so it takes some time.
Old Dec 26, 2007 | 09:43 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Remember, 20 seconds cranking, 2 minutes cooling time for the starter before cranking again.
Old Dec 26, 2007 | 10:28 PM
72f2504x4390's Avatar
72f2504x4390
When I changed my IP, it took for what seemed like forever before I started seeing anything at the injectors.
I even removed the IP cause I thought it wasn't pumping but it pumped on the bench so I put it back on. I bet I did 15 cylces of 20 seconds cranks.
Old Dec 27, 2007 | 12:05 AM
PLC7.3's Avatar
PLC7.3
I found if I disconnect the IP FSS before attempting a start or purging the lines after a filter change (filled filter) and do only a 15 second cranking, the fuel/air is usually past the IP. So then when you connect the FSS the metering valve opens and only allows fuel into the pump and injector lines. Ensure if you pre fill the filter you do it into the outer circle of holes..... the large hole is the filtered fuel area.
Old Dec 27, 2007 | 08:44 AM
TurtleRacing
PSD Addict
What is the FSS?
Old Dec 27, 2007 | 08:47 AM
fellro86's Avatar
fellro86
Fuel Shutoff Solenoid, the heavy red(if I remember right) wire to the injection pump
Old Dec 27, 2007 | 09:24 AM
PLC7.3's Avatar
PLC7.3
Sorry.. IP (injection pump) larger front connector drivers side (USA)
Old Dec 27, 2007 | 10:07 AM
TurtleRacing
PSD Addict
So you're saying to disconnect this and crank?
Old Dec 27, 2007 | 10:10 AM
TurtleRacing
PSD Addict
One more question I have, should I crack all 8 lines or just one? I've seen half say one, and the other half say all.
Old Dec 27, 2007 | 10:15 AM
fellro86's Avatar
fellro86
That is what he is saying, it will fill the holding area of the IP without putting it into the pressure head, and will clear out the return lines. I crack all 8 at the same time, hasn't ever been an issue so far, been doing it that way for years.
