Ticking sound
Old Dec 23, 2007 | 02:08 PM
lazy ike's Avatar
lazy ike
Ticking sound
I was driving the other day and the engine started to tick(90 f-250 7.3). It sounded like the fan was hitting something from inside the cab. When I checked under the hood, the sound appears to be emminating from passenger side front. I am now getting smoke under load and rough running all around. I threw a new fuel pump in with no change. Any ideas where to look next? Thanks
Old Dec 23, 2007 | 05:00 PM
KJLYPW's Avatar
KJLYPW
Injector noise-missfire. Are you using a fuel lubricant additive. If not give it a double or tripple dose, see if things improve. If not you are likely looking at replacing injectors.
Old Dec 23, 2007 | 06:19 PM
lazy ike's Avatar
lazy ike
I do run a lubricant occasionaly so I'll try that first thanks.
Old Dec 23, 2007 | 06:28 PM
sampatton's Avatar
sampatton
might be something valve train related also
Old Dec 23, 2007 | 06:32 PM
ajjs's Avatar
ajjs
I've been reading about the HIMAC pcv jar and was wondering what is the thinking on its performance now. I have a 1987 I6 f150 4x4 four speed and a 1981 Jeep J-10 258 I6.
Old Jan 6, 2008 | 10:24 AM
lazy ike's Avatar
lazy ike
Well, a couple of new injectors have not solved the problem so any ideas what I can or should do to check the valve train? Thanks
Old Jan 6, 2008 | 10:51 AM
PLC7.3's Avatar
PLC7.3
How many miles on the engine....... could be a rocker assy is worn out. Remove the valve cover and check for sloppy rockers.......bent or broken parts especially valve springs. When the cover is off post back with what you see......
Are you getting any loud wooof wooof in the intake or chuffing at the exhaust.
Old Jan 6, 2008 | 06:27 PM
Wookie35's Avatar
Wookie35
I have the same thing going on after driving on the HWY for about 10-15min. My Dad-in-law (Old diesel tech) says fuel filter, but it is engine speed dependant and slows/quiets down when I put the clutch in. I thought it might be fan/belt related as well but by the time I get to my house from the freeway the sound has gone away.
Old Jan 6, 2008 | 07:32 PM
Jake S's Avatar
Jake S
I have a bad lifter where the needles came out of the roller. Was quiet, coming and going, then louder. Now sounds like a rod knock. I would suspect valvetrain.
Old Jan 6, 2008 | 08:11 PM
PLC7.3's Avatar
PLC7.3
Jake I think your roller lifter is Fubar and taking care of the cam for you....... ouch.
Old Jan 6, 2008 | 08:29 PM
Jake S's Avatar
Jake S
Good thing I have spare motor. Going to take turbo off tomorrow and see it first hand. When the pushrod suctions to the lifter I can pull the lifter up and hear funny sounds.
Old Jan 12, 2008 | 09:32 AM
lazy ike's Avatar
lazy ike
Well the valve cover came off to reveal a spring sitting sideways and a valve guide in a couple of pieces. I don't expect I am going to be able to replace the guide easily?
nduclet351
Apr 26, 2013 09:26 AM
JDW124
Jun 15, 2010 09:27 PM
STROKER350
Jun 4, 2009 08:42 AM
seebeew
Exhaust Systems
Sep 5, 2001 03:36 AM
tank5879
1978 - 1996 Big Bronco
Feb 1, 2001 06:28 AM
