antifreeze
Old Dec 23, 2007 | 06:33 PM
sampatton's Avatar
sampatton
antifreeze
okay so i am going to change my anti freeze before winter really hits and i found two different ones.
http://www.fleetchargeantifreeze.com/fleetchrg_spec.htm this one i can get a tractor supply
http://www.fleetchargeantifreeze.com/finalcharge.htm or this one i can get at the local walmart.
Both about the same price is there a difference between the two of them? any one have any experiance with either one. Also do the come prediluited or do i have to do that?
Old Dec 23, 2007 | 07:17 PM
lowell75's Avatar
lowell75
from the little research i've done definitly stay
with the 1st one (conventional green).. The OAT-
dexacool types have been nothing but a problem
sence GM started using & specifying for warrantee
in 95'. Google on; san carlos radiator while your
waiting for more opinion here!
Old Dec 23, 2007 | 09:01 PM
deanzawistowski's Avatar
deanzawistowski
ive never changed mine either, what are some recommendations?
Old Dec 23, 2007 | 09:23 PM
knash0727's Avatar
knash0727
Get the First, but try to get the 50/50 so it is already diluted
Old Dec 24, 2007 | 02:40 PM
Dave Sponaugle's Avatar
Dave Sponaugle
I run Fleetcharge in mine.
The local Tractor Supply only carries the non diluted version, which needs to be mixed with water.
On the plus side, they sell it for almost the same price as NAPA charges for the 50/50 mix.
4 gallons of 100% and 4 gallons of distilled water or 8 gallons of 50/50 with no water added.
Old Dec 24, 2007 | 03:40 PM
brownieboy525's Avatar
brownieboy525
stick with the white bottle the stuff in the black bottle is known to make a gooey mess if mixed with anything else. i run fleetcharge in mine and so far so good
