460 testing compression
Old Sep 14, 2001 | 10:41 AM
69crewcab's Avatar
69crewcab
group
i have a 77 460 that i pulled from a local u pullit for
a whopping $1 yes thats one dollar, it was a special..it
actually costed me $20 to get in and all parts were a $1
anyway, i get it home put it on a stand, and go to
check compression and it has NONE...barely 30 pounds in 2 cylinders...Now this is with the carb and plugs out and the
air pump removed etc...Where should i check next???Can this
be possible???I can hear compression, but it seems not on every
turn of the crank..I check the compression gauge on another
motor and it does work fine..
Old Sep 14, 2001 | 12:51 PM
79F2504x4's Avatar
79F2504x4
[font size="1" color="#FF0000"]LAST EDITED ON 14-Sep-01 AT 01:57 PM (EST)[/font][p]Well there buddy, you get what you pay for. Tear it down and check the internals. if you have one cylinder leaking into another, and no spark plugs in it, most of the compression excapes. The air is going to take the path of least resistance weather it be through a crack or bad seals. If its easier for the air to go through seals or a crack than to register on the gauge its gunna do it. All meaning it needs a rebuild if every thing else is ok.
Hope this helps
Chase
1979 F-250 4x4
71 460 Holley650, MSD OFFROAD
C6-B&M Transpack
Dana HD44Front/60Rear 3.73 Limited Slip
35 inch Goodyear Implement Tires
4 inch Skyjacker System
Will get souped up soon
Old Sep 14, 2001 | 01:33 PM
jim henderson's Avatar
jim henderson
Yeah, most of those jumk yards know what they got and they almost never give anything away. Most likely that engine was a totally worn out war horse in need of a complete rebuild. Although I suspect that he wouldn't give it away for $1 if it had a rebuildable core. The other possibility is that someone left the engine open and over the years water got in and rusted things so maybe the valves are stuck/busted, timing chain busted, piston rings dissolved into rust.
But from the sounds of it, at best, you have a block that requires a full rebuild. At worst, you may just have a pile of parts that might be usable in some other engine.
Sorry, hope we are wrong.
Jim Henderson
Old Sep 14, 2001 | 02:11 PM
69crewcab's Avatar
69crewcab
the motor only had 77,000 miles, and the yard i pulled it
from won't test motors from 91 on back(its not worth there time)
as they say. Well i guess its time to tear it apart..
Old Sep 14, 2001 | 02:39 PM
Bill_Beyer's Avatar
Bill_Beyer
group
I've never tried to do a compression check on the stand. How are you turning it over? Can you turn it over fast enough by hand to do a decent compression check? Have you tried squirting some oil down the cylinders to see if it seals up?
I've seen a lot of "All you can carry in 1 trip for $5.00" and similar junkyard sales so I know what you mean.
Old Sep 14, 2001 | 05:51 PM
Torky's Avatar
Torky
Pull one or both valve covers off. It may be obvious, like bent push rods, valves stuck, etc. Maybe no cam rotation, like broken chain as mentioned. A cylinder with both valves closed still can show very low compression, not always zero, air slips by. May even wheeze for a moment after you turn off the starter. Not necessarily toast yet.
Old Sep 14, 2001 | 06:35 PM
69crewcab's Avatar
69crewcab
I'm turning the motor over by socket and ratchet..could this
be a problem???
Old Sep 14, 2001 | 09:34 PM
bgroves's Avatar
bgroves
Normally you test compression using the starter, perhaps it's not as bad as you first thought :-)
Do you know anyone with the gear and experience to do a leakdown test on it ?
Brian
Old Sep 14, 2001 | 11:42 PM
Bill_Beyer's Avatar
Bill_Beyer
I'm turning the motor over by socket and ratchet..could this be a problem???
I'm thinking you may not be able to do a decent compression test without turning it over at a pretty decent RPM. Try putting your thumb over one of the spark plub holes and turning the engine over. If it develops enough pressure to push the air out past your thumb then you're probably OK.
Old Sep 15, 2001 | 12:01 AM
Torky's Avatar
Torky
I didn't catch that it wasn't in the truck yet. I know I sure couldn't spin a 460 fast enough with a rachet for meaningful compression numbers! As others said, at starter speed with a charged up battery for at least 5 power strokes or so for the cylinder under test to get relevant numbers.
Old Sep 15, 2001 | 06:10 AM
69crewcab's Avatar
69crewcab
thanks guys
yes it does make pressure and push my finger off the holes...
so the hand cranking is the problem..Could i mount a starter
and turn it over on the engine stand???
Old Sep 15, 2001 | 08:16 AM
classic79's Avatar
classic79
What are you wanting to do with the motor? Just drop it straight in a car or truck? You only have what $1 in it now right? If you have it on the stand, I would at least go through and put new seals, and gaskets on it. That would give you an opportunity to look inside the engine. If it needs a full rebuild you are still way ahead on the money end of things. Heck I paid 300 for a 460/c-6 out of a lincoln that was running, with the full intention of rebuilding it with forged pistons, solid cam, etc..
Basically don't worry about the compression test too much unless you are going to just drop it in something.
chris
79 F-150 Ranger Lariat, 2wd, RC, LB, 460 (intake, headers, cam), C-6(shift kit).
79 mustang (work in progress...its just slow progress)
98 Chevy 4x4 (work truck)
95 Lexus SC300 (wife's baby)
Old Sep 15, 2001 | 08:10 PM
77_f250_460's Avatar
77_f250_460
ScottJM
24
Oct 22, 2018 05:45 PM
nickydobbs
Sep 17, 2014 11:58 PM
obscurity
16
Aug 30, 2014 03:29 PM
PM PAINTING
Apr 8, 2011 10:23 PM
FatMike86
Jul 20, 2002 06:16 PM
