mix-match 460
Old Sep 7, 2001 | 10:52 AM
f350brocno's Avatar
f350brocno
mix-match 460
Old Oct 18, 2001 | 01:31 AM
bonzi88's Avatar
bonzi88
mix-match 460
Planning on 460 conversion in my 1979 4x4 Supercab.I already have
a 1970 Lincoln 460 that runs great,but big compression & soft valve seats.I just acquired a 1978 460 from a 1-ton van,rear sump and all,runs but tired.If i put the '78 heads on the Lincoln motor....What kind of comp. ratio will i get?? I'm not interested in way huge horsepower,just long time reliability and torque for pulling 26ft camper.
Old Oct 18, 2001 | 09:11 AM
georgedavila's Avatar
georgedavila
mix-match 460
About 9.1:1. Pretty low but better than the 8.0:1 of the '78 engine. Why not use your '70 engine with the 10.5 c/r? If you have your ignition curve set on a conservative basis, you shouldn't have any problems. I've been running early heads with non-hardened seats on non-leaded gas for many years and lots of hard miles without problems or any sign of abnormal seat wear.
Here's a post by a respected engine builder from another list:
-> My question is about hardened valve seats, I have put them
-> in the past rebuilds I have done, but since then I heard
-> some people say that they weren't nessecary. I learned they
Inserted seats are for repair. They interfere with heat flow from the valve; the ports have to be ground to blend the seat in; improper installation (can you tell with your naked eye?) will let them come loose, with potential for catastrophe. The cutting necessary to install the seats weakens the head and can promote cracking, particularly if the head is subjected to higher than stock pressures or heat, ie a high performance engine.
You want inserted seats about as badly as you want a veneral disease.
Most shops call them "hardened" seats; most inserts are plain old cast iron, like they just carved out of your heads. True hard seats are Stellite and they cost over $10 each, and they're righteous (expletive deleted) to cut a seat on.
Old Oct 19, 2001 | 12:19 AM
TBirdGuy's Avatar
TBirdGuy
mix-match 460
Use the older high compression heads, but have hardened seats installed. A good friend of mine is the head machinist at the local shop that I have all my work done and he's shown me ALOT of heads that run unleaded gas with non-hardened seats. He's built (documented) well over 2,500 motors. You'd be surprised at just how much damage that really does. Besides, if your really worried about having the installer screw up, perhaps you shouldn't take your parts to that shop. Just my input.
TBirdGuy
"Stuck with a m*par, Settle for a ch*vy, Happy with a Ford!!!!"
Old Oct 19, 2001 | 12:29 AM
Mil1ion's Avatar
Mil1ion
mix-match 460
https://www.ford-trucks.com/dcforum/User_files/mil1ion/3bcfba245551d8d7.gif
https://www.ford-trucks.com/dcforum/User_files/mil1ion/3bcfba0d5514d08c.gif
I concur.
I had stelite exhaust valve seats put in my 429CJ when I installed the 429 in my truck.
The shop that did it showed me what happens if you don't.
So far another 150,00 miles with NO PROBLEMS and lot of compression.
If you can't act your age,
Then act immature !
Red Green, CBC
TBirdGuy
Dennis
Old Oct 19, 2001 | 01:59 AM
TBirdGuy's Avatar
TBirdGuy
mix-match 460
Ummm,
I kinda hope I mis-understood your reply, mil1ion. Were you implying that I acted/said something immature? If I did and offend someone, I'm sorry. I don't think I did, but I'm not perfect. Just checking.
TBirdGuy
Old Oct 19, 2001 | 02:29 AM
merc460's Avatar
merc460
mix-match 460
hey dennis I don't think are american freinds know who red green is, as far as seats go I sank two exhaust valves in my 68 heads switched to hardend seats and no more problems
Old Oct 19, 2001 | 01:18 PM
Mil1ion's Avatar
Mil1ion
mix-match 460
https://www.ford-trucks.com/dcforum/User_files/mil1ion/3bd06e275963ba89.gif
https://www.ford-trucks.com/dcforum/User_files/mil1ion/3bd06e0758da0bc3.gif
Ummm,
No offence meant !
Red Green ( his real name Smith) is a middle aged comedian in Canada and has had a few television shows .
Presently the Red Green show is directed act Middle aged men at a Lodge in Ontario.It appears on the Comedy Channel and the CBC.
What I wrote is one of his Quotes.
Another one is:
" You know I'm pulling for ya,Cause we're all in this together"
Red Green , CBC
Dennis
TBirdGuy
Dennis
Old Oct 19, 2001 | 01:29 PM
TBirdGuy's Avatar
TBirdGuy
mix-match 460
That's cool. I just wanted to check. I know who Red Green is. We get him here (well, used to) on PBS. He's pretty funny, along with his goofy nephew with the keyboard/guitar thing. I like the way he fixing everything (including a windshield once) with duct tape.
TBirdGuy
Old Oct 19, 2001 | 07:16 PM
bonzi88's Avatar
bonzi88
mix-match 460
What's so bad about a 9:1 460.I mean I'll be comparing this to the original 400M that's so tired it can't even muster up any oil pressure at idle !!!!!"10.5:1 motor" sounds cool I don't if the price of hi-test is practable.This is a work truck.The $$
for the head work alone could go towards a set of L&L headers!!
" Oh honey....we can afford to go camping again when the 'good' stuff drops under $3.00/gal.And as for the race car...I drive it to the track!!!"
" Well i thought you put all that work into that truck so that we could ............"
A 9:1 460 with headers,decent cam,proper tuning will put out what (on 87oct fuel) 170 hp?????!!!!!!!
This is the impression I'm getting.
Oh ...did i say i was on a bit of a budget..??
Old Oct 19, 2001 | 08:26 PM
bgroves's Avatar
bgroves
mix-match 460
What do you mean we yanks don't know who Red Green is ? where the heck do you think most of us learned how to use duct tape from ?
Old Oct 19, 2001 | 08:36 PM
Bill_Beyer's Avatar
Bill_Beyer
mix-match 460
'S right!
If the women don't find ya handsome they should at least find ya handy!
Old Oct 19, 2001 | 10:36 PM
bonzi88's Avatar
bonzi88
mix-match 460
And here i thought this was a Ford enthusiats group!!!!
Silly me.
Old Oct 20, 2001 | 12:48 AM
merc460's Avatar
merc460
mix-match 460
Well it is refreshing to see that some canadian culture travels south
Old Oct 20, 2001 | 08:35 AM
georgedavila
mix-match 460
[QUOTE]A 9:1 460 with headers,decent cam,proper tuning will put out what (on 87oct fuel) 170 hp?????!!!!!!! This is the impression I'm getting.
I'd think about 270hp with 450ftlb torque, a little more if you match the intake manifold to the head ports. That should get you to work and back and take you camping on 87 octane. Your cam is the major player only to a certain point with lower compression ratios. HP numbers sound nice, but torque and where it happens for your purposes is what counts.
