429 balancer
Old Sep 14, 2001 | 12:03 AM
mclerico's Avatar
mclerico
429 balancer
Old Oct 3, 2001 | 09:50 PM
greenhighboy's Avatar
greenhighboy
429 balancer
I have a 68 429 that has the harmonic balancer with the pulley grooves made in it that has slipped. Does any one know of a company that repairs balancers or were a new one can be bought.
Dennis Palmer
Old Oct 4, 2001 | 12:31 AM
proud owner's Avatar
proud owner
429 balancer
Pulley grooves are actually cast into the balancer? no bolt-on pulley... Hummmm. that's new to me.. lol I'd say try finding another one off a similar engine... Or convert to the bolt-on pulleys, which I think would be better, as they wouldnt put as much load on the balancer to make it slip... (common sense? I dunno.) Best of luck to ya!
J/.c
1965 Ford Galaxie 500 (okay, so not quite a truck)
ANOTHER 460/C6 @ 365hp/519 lb.ft.
14.36@100.4, 16-18 mpg AHHAAAHAAAHAAA!
Old Oct 4, 2001 | 08:24 PM
greenhighboy
429 balancer
The balancer has two grooves in it that run the alt.,the pulley for the power steering does bolt on.I have this motor in a 77 highboy and eveything of the car worked perfect so I would like to keep it like it is if possible.Changing over to the other style I would have to change the water pump and all the other pulleys and maybe the power steering brackets.
Dennis
Old Oct 6, 2001 | 10:47 PM
proud owner
429 balancer
once again, I'd suggest finding another one off a similar engine.. maybe at a swap, probably in a junkyard. Otherwise, check your local parts houses and mechanics, try and find someone locally who would be able to repair it.. Once more, best of luck to you..
J/.c
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
